Hi all, I posess a PowerPC 867MHz G4 with Superdrive. Can you suggest me some dvd media that works fine with superdrive? i have read somewhere that with some media the probability of failing the burn is really high.
Thanx
reb
reboundingGuest
Hi,Originally Posted by rebounding
i have noted that burning dvd movies at 2x causes some problems (mainly with apple's first generation dvd-r). i have used different brands without problems and no coasters: apple (first series), primeon, parrot, mitsui silver. i have a quicksilver 867 with pioneer a03 and recommend burning at 1x only.
cheers
Wayne TGuest
Best media are Apple and Pioneer Branded. But plenty have used others....
The suggestion about 1 speed burn is good advice- particularly for Video DVD which you'd like to be playable in/on as many consumer players and computers as possible.
With Data DVD for your own use, it doesn't matter much.
That said, I use Pioneer or 'Laser' DVD-RW for nearly everything (it's a 1 speed burn for me) : if anything screws up a burn (rarely happens to me) I just erase and do it again (Good for when I miss some stupid error in a menu or similar when I'm tired/rushed....
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
