I have studied the plethora of posts here about favored DVD authoring programs. DVD workshop was looking very popular until I saw it was the same guy on every tread touting it (90% of te time) <grin>. I see Maestro is very popular and I have it available, BUT....
Before I learn to use something that is obsolete from the get-go, can someone tell me if it's copatible with the HP 200i DVD +R/+RW burner? I don't want to even install it if not.
Or maybe I'm getting ahead of myself, I'm assuming it handles the burinig, maybe I need to use a different product for the actual disc burning? Obviously I'm a newbie, help and pointers appreciated.
Cheers,
Maestro is not a burning program, it's an authoring program.
You will still need dvd burning software to burn the files Maestro authors. Your HP drive should come with burning software.
Amazing that someone would drop several thousand dollars on a piece of software when they are unclear what it does...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
DVD Maestro may not support your burner but it will do the authoring for you. You can always use another tool like Nero, DVDdecrypter etc. to burn the VIDEO_TS folder. Maestro will create a .IMG file which DVDdecrypter will burn.Originally Posted by shorton
Guides for Maestro can be found here:
Spruce DVDMaestro
http://www.geocities.com/eaussie01au/maestro.html
https://www.videohelp.com/forum/userguides/146371.php
http://digital-forums.com/dvd2dvdr/intro.htm
http://www.fukrulez.com/modules.php?name=Content&pa=showpage&pid=11
http://www.doom9.org/mpg/maestro.htm
http://www.doom9.org/mpg/maestro2.htm
http://myweb.cableone.net/trilight/dvdguides/multipgc/default.htm
http://www.tcnj.edu/~sarnell2/ART34508/dvd2dvdr/index.html
https://www.videohelp.com/forum/userguides/140765.php
You may want to try DVD-lab or TMPGEnc DVD Author. They both can author and burn DVD's I beleve they are both availabe for 30 day free trial.
Guide for DVD-lab here:
http://www.mrbass.org/dvd2dvdr/
Guide for TMPGEnc DVD Author here:
https://www.videohelp.com/forum/viewtopic.php?t=161658&highlight=surefire -
Wow! Thanks very much for th etime to gieve such a through response. Much appreciated!
Cheers,
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Is using a Bluray drive better than a regular DVD drive?
By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 21:49 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Lite-On drive LH-16W1P DVD-DL drive
By snafubaby in forum MediaReplies: 8Last Post: 28th Apr 2008, 16:00
