Vertical alternating lines appear in my Divx file!
Is there any way to remove these lines?
Is this a bug with mmpegx?
One set of lines is blurry, the other is very sharp.
The blurry lines mostly blur the colors blue and red. So if someone in the video is wearing something blue, and if its on a blur line, it smudges!
I have noticed that my file's brightness was boosted when i encoded it, but I have NO idea why these things are happening!
(The raw file is FINE.)
Guest
Guest
could someone please answer my question?
MakoGuest
I'm not the guy who first asked the question,but I'm having the same problem. Here's a sample clip:
http://steelbluepanic.com/ffmpegx/sample-ffmpeg-mp4.avi
I'm trying to start with a large DV stream file (.dv created in QT Player), and downsize it to a 384X288 AVI file at rather low bitrate (450kbps). However, whenever I try to process a DV stream (haven't tried any other filetypes) with any of the ffmpeg codecs, I get this weird vertical striped color bleed on reds, as shown in the clip above (look at the girl's dress).
I've tried just about every combination of options (the one above has everything off, including deinterlacing), as well as different (small) DV source files, and it always shows up on anything done with any ffmpeg-based codec.
The mencoder versions of the codecs produce gorgeous video with identical settings based on the same source files. Unfortunately, I also can't get the mencoder codecs to do any input file larger than 2GB, where the ffmpeg ones don't mind.
Any suggestions?
GuestCertainly:Originally Posted by major
http://steelbluepanic.com/ffmpegx/shortsample.dv
And the file I get from it:
http://steelbluepanic.com/ffmpegx/shortsample.avi
I hope somebody can figure it out.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Convert DivX file with subs
By marioval in forum Video ConversionReplies: 6Last Post: 17th Oct 2010, 17:23 -
lines when I convert VOB to AVI
By odiedog in forum Video ConversionReplies: 1Last Post: 31st Jan 2009, 18:46 -
How do you convert DivX file w/4 subs to AVI?
By JoeBolden in forum Video ConversionReplies: 2Last Post: 21st Nov 2007, 15:58 -
I have downloaded file clips in .divx how can I convert to .avi?
By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 14:36
