Hello. I wonder if someone might be able to explain this for me. I ripped the Super Furry Animals - Rings Around The World DVD, using Smartripper, then used DVD2AVI which left me with 13 wav files (2ch 448Kbps 48KHz). I then used Musicmatch to convert them to mp3, but upon playback they have a high pitched ringing tone throughout the songs (even encoded at 192kbps). Have I done something wrong? Does Musicmatch just suck, or could the audio be protected in some way? It sounds ok played as wav. Hmmn. If anyone can help me I'll be very grateful. Cheers.
Do you normally encode mp3's from such a high quality source? If it was the first time then I suggest that you try to encode another high quality audio source to see what that turns out like. You could also try using a different encoder. I think that the problem lies with the encoder.
Thanks for the pointer - you were right, it was the encoder causing the problem. I had a bit of a look around for encoders - http://users.belgacom.net/gc247244/analysis.htm was a bit of an eye opener for me. And sure enough, LAME worked great - http://home.pi.be/~mk442837/lame3.89beta.zip for anyone attempting to do something similar to me.
Yeah, I was going to tell you to get Lame, its the best. Some encoders are pure crap as they cannot deal with certain sampling frequecy rates and bitrates.
MP3 or WAV?
By Charmer in forum AudioReplies: 4Last Post: 6th Aug 2009, 19:20 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 23:45 -
AC3 (5.1 or 2ch) to 2ch mp3
By shun in forum AudioReplies: 4Last Post: 11th Nov 2008, 08:50 -
mp3 to wav
By stewart2000 in forum AudioReplies: 8Last Post: 27th Sep 2008, 06:12 -
5.1 AC3 to 2ch mp3 error's in VDubMod
By Sykotik in forum DVD RippingReplies: 0Last Post: 20th Oct 2007, 07:53
