Is there any reason to burn anything but the 5ch or 6ch off of a DVD?? If you burn either of them won't it still be in stereo if you are using a 2ch setup?? i dont understand why you would burn the 2ch if you have the option to burn the multichannel if the multichannel can be used if you are using a 2 speaker setup or a 6 speaker setup....is this correct???
I usually only burn the 5.1 or 6 channel to save space. I'm always worried that if I have an extra channel it will get forced on or be the default and I won't be able to change it from the player.
You will laugh, but right now I only have 1 channel on my set up. I built a new house and only have the center speaker set up.
Thus I hear all the sounds out of one speaker. I would imagine that more speakers would get you stereo at worst. -
If you're concerned about audio quality, a dedicated stereo track will sound significantly better than a 5.1 DD fold-down on a stereo system. That's really the only reason to include that track.
Philbiker -
well see sometimes i play them upstairs on my 5.1 or sometimes downstairs on my 2 channel.....so you think burn both then always?
It depends on how picky you are about the stereo sound. The 5.1 will be made into a 2 channel track when it's played. Personally I wouldn't worry about the fidelity and I'd ditch the 2 channel track but some people are more picky about audio than I am.
Philbiker -
aaaa.... I like the audio commintary so if its on there I will burn that also, other than that go 5.0, 5.1 or 6.1 only, leave the foreign lang. and subtitles off.
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
need to substitute spanish audio track with english track
By rebeltaz in forum AudioReplies: 5Last Post: 26th Dec 2007, 20:12 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 09:25
