Prassi Primo and Record Now are the same programs. I can't get them to make a playable disk. The ifo files are always empty on a disk I burn with either program. I check the ifo file in the source directory and it contains the detalis to tell the player how to work,but when I look at the ifo on the DVD-R that was burned it's empty.no information. It has the correct byte size but it's empty. What could cause this?
maybe the file is locked on your hard drive ... so it would not get burned
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
