Greetings from Puerto Vallarta, Mexico
I was unsuccessful in playing a SVCD disc I encoded recently on my DVD player, a Sony DVP-NS315. Upon checking the compatibility list, however, it was listed as "compatible." Furthermore, someone added a report claiming that he was successful in playing SVCDs on the player, but only when using the "VCD header trick."
Can anybody think what this might refer to, specifically? If it's helpful, I'm using Mac software to author my VCD's and while picture quality is OK at VCD resolution, I'd like to explore the higher resolution available in SVCD's.
Results 1 to 12 of 12
you remux your mpeg2 as a non standard VCD Mpeg1, easly done on windows using TMPGEnc, I have no clue how you would do it on a Mac. Goto the Guides section, they'll explain how to do it w/ windoz
Originally Posted by ojedapaco
that being said, the main problem with playback is how you burn the svcd
Typically those who burn these disks in Toast report problems with compatiblity of players
for example i have APEX 5131, it will not play a Toast burned SVCD
however, burn the same file using Missing Media Burner, or Firestarter and it will play
tell me more about the source, how you burned it etc and i can help you out more.
thanks
/Galactica -
Success!
I'm happy to report that I was able to convert a short MOV into a SVCD that played properly in my Sony DVD player, using MMT.
Upon return from a biz trip, I will summarize my procedure and share it with all.
Thanks again,
Paco Ojeda -
Mr. Ojeda---
I am on a Mac and have the same Sony player as you. I am very intrested to hear the procedure you used.
Thanks in advance. -
Originally Posted by Ejoc
Geeee. How useful. Please read the forum rules before posting. We don't need winblows answers in the mac forum. We don't want to lower ourselves to that level. :P -
TGPO
this was stuck in the PeeCee dominated SVCD forum, so it was moved because of the lack of response and the reply you just pointed out! -
I have a Daewoo 5800 and this is what i can do to get SVCD playback.
MPEG-2 file must be in BIN format (vcdtools x does the trick)
In Toast use Multitrack XA mode and drop in this little file called" First T01 Mode2 2352.iso" then drop in the BIN file and burn.
I have another DVD player, but it doesn't work on that one.
the big problem is where to get the " First T01 Mode2 2352.iso" file.
I happened to pick it up a while back in one of the newsgroups, like alt.binaries.mac.applications -
Originally Posted by tgpoAs below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
If you take the elementary streams of an SVCD and plug into FFMPEGX's Video Tools, mux as VCD, is this the same effect, on the Mac, as the Windoz's TMPGEnc's "VCD Header Trick?"
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
All captured video has "Corrupt Header"
By raihnman in forum Capturing and VCRReplies: 2Last Post: 8th Mar 2009, 15:52 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
