Does anyone have a guide as to how to use the program Sizzle? Also if I have a large file how do i break it up into "chapters"
Here's some useful information on sizzle (and the dvd authoring process using sizzle)
keep in mind there are other apps that will do the same things as the apps listed in this list. so if you prefer one over the other you can always use that as long as you know it makes the same thing.
Sizzle help
By danielmak in forum MacReplies: 3Last Post: 3rd Mar 2010, 07:37 -
Dealing with VOBs, subtitles, Sizzle and Miyu
By silverspell in forum MacReplies: 4Last Post: 25th Feb 2009, 06:57 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45
