    missing in action
    i have just backed up 1 of my dvd r with smartripper and it has left me with 2 files.
    MPA T01 DELAY 0ms.mpa for the audio and a movie.mpg.
    any 1 have any idea which software is best for putting these back together as an vcd or svcd.
    many thanks
    mark
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    They have to be reencoded (and multiplexed) to (S)VCD compliant mpeg using movie.mpg as video source and MPA T01 DELAY 0ms.mpa as audio source. You can use TMPGEnc or other mpeg encoder for this.
    /Mats
    missing in action
    thanks mat
    looked for instructions on how to do this but cant find em.
    any chance u can point me in the right ditrection.
    many thanks
    markyp1969
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, starting from scratch, I'd get TPMGEnc.
    Then install the trial version of PowerDVD to enable TMPGEnc to read mpeg2.
    Start TMPGEnc, select the right PAL/NTSC VCD/SVCD template from the wizard, use movie.mpg as video source and MPA T01 DELAY 0ms.mpa as audio source and hit "Start" (and possibly go to bed).
    /Mats
    missing in action
    Many thanks mat.
    nearly pulled all my hair out but luckerly u got here just in time and now its just a bald spot on top.
    many thanks m8
    ps
    u any good with divx conversions
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Can't say I am - If you mean converting from DivX to (S)VCD, I've more or less given up, as dled DivXs are all crap more or less. When I do, I first clear out all bad frames in Virtual Dub, then extract the audio track and decode to wav. Then frame serve the cleaned video from VDub, using the wav as audio source.
    If you mean encoding from DVD to DivX, I mostly do that under Linux, using DVD::RIP, which, once it's all installed, outshines any Windows DVD2DivX/XviD/anything I've come across.
    /Mats
