the intro WAVE and intro AVI are both 9.000 seconds exactlyCode:video=avisource("intro.avi") + avisource("harrychamber.avi") audio=wavsource("intro.wav") + wavsource("harry1.wav") audiodub(video,audio2)
and harrychamber AVI and harry1 WAVE and both from the same AVI and were in sync
both AVI's are Xvid encoded the same and the WAVE files are both raw WAVES
any ideas ???
what am i just over looking totally
OH the Audio is way behind the video
thanx
AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb -
What are you encoding to?? Your .wav files should be resampled to 48khz or 41khz beforehand...
I'm guessing that's the problem...
Good luck...... -
pijetro,
Could you explain why resampling the audio first would fix the sync problem? It's a genuine question because I can't see how they're related. -
http://nickyguides.digital-digest.com/fix-audio.htm
Basically, the VCD and SVCD takes 41khz, and DVD takes 48khz. If at anytime there is a conversion from one to another, then you get stretched or shrunk audio. The first few paragraphs basically say samplerate conversions, are like framerate conversions. Thank goodness for Vdub, and/or CoolEdit (not free)...
The guides in the left show you how to extract the audio from Vdub, without stretching the .wav.
If I remember correctly, Video>directstream copy, Audio>fullprocessing , Audio>conversion(48000), Audio>compression>pcm , File>Save .wav.
Your audio should be good to go....
Good luck!!!!! -
ahh that could be it!!Originally Posted by pijetro
not encoding to anything when i lose sync, just simple playing the script
i'll look at their sample rates when i get home ...
thanxAMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
avs script giving me fits
By willmoodom in forum Newbie / General discussionsReplies: 32Last Post: 30th Sep 2009, 03:43 -
How do I create an AVS script
By Sopt Finder in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 13:17 -
AVS script and Subtitle Workshop
By sambat in forum SubtitleReplies: 3Last Post: 19th Apr 2009, 10:20 -
This correct avs script for this source?
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 01:24 -
help with avs script (dv to mpeg2) Fading in/out
By ZiGGY909 in forum EditingReplies: 2Last Post: 14th Nov 2007, 14:12
