Hello
I hade a movie in two parts that i made to SVCD, and wene i use TMPGEnc Mpegtools to join the files the file gets a fakesize.
Wene right click on it and select properties i get the size 798mb, but wene im about to burn it with Nero i got 900mb as size. Why dose this happen?
And then i have to re-encode the joined file agaion to get the corect size.
Plz help me out.
Thx
USiT
Don't use Nero to author (which is what you do, if you use Neros SVCD wizard). Author with VCDEasy (1.1.4 latest free version), and if your system isn't supported by VCDEasys burning engine, just create the cue/bin with VCDEasy and burn that with Nero. Depending on CD-R and burner, you might (barely) squeeze 798 MB mpeg on a 80 min CD-R
/Mats
Avidemux Target Size Problems
By FrozenInferno in forum Video ConversionReplies: 10Last Post: 2nd Apr 2011, 14:52 -
xvid target size problems
By Cowabunga in forum Video ConversionReplies: 13Last Post: 16th Jan 2009, 15:11 -
Problems With Video Size
By Jake802 in forum Video ConversionReplies: 2Last Post: 5th May 2008, 22:01 -
PowerDVD playback problems Plz help
By ian curtis in forum Software PlayingReplies: 8Last Post: 25th Oct 2007, 03:40 -
Size problems with DVDAuthorGUI
By supernano in forum Authoring (DVD)Replies: 5Last Post: 12th Sep 2007, 02:29
