I've taken color movies like Red Planet and converted them into mpg files. Theey were still in color at that point.
Using either nero5.xx or in another computer using ez- CD creator 5.0 plat, when I finished the burn they played in Black and white on my Philips dvd player.
Any ideas?
Ez
This sounds like a NTSC/PAL issue to me.
If your tv-set does not support both formats, check if you can set your DVD-player to output everything at the format that your tv-set accepts.
If this isn't possible, you need to make sure that you encode and author your VCDs according to NTSC or PAL specifications - depending on where you live.
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
black and white
By foofie131 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 22:15 -
Do you take black and white photos at all?
By yoda313 in forum PollsReplies: 15Last Post: 28th May 2008, 08:58 -
Playback in black and white
By verm1n in forum Portable VideoReplies: 3Last Post: 29th Dec 2007, 05:54 -
HELP, every video on my PC is Black and white ?
By shammi in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2007, 08:52
