is it possible to convert a .wav file to a .mp2 file if it is possible can anybody tell with waht program to do this and where i can find that program?
greetz, Shops
U can use tmpgenc: unlock the settings >> load wav >> choose audio only >> Start. Results sould be mp2. Then use bbmpeg to mux mp2 & mpv. See how to make s/vcd with bbmpeg.
I would recommend using tooLame, you can run tooLame throguh TMPGenc if you want thou (tooLame is a dos program)
On a related topic, sometimes I get an error when using TooLame in TMPGEnc, and then I would have to close TMPGEnc. Anybody run into the same problem. It only happens occasionally on my system, but it causes problems since I often do batch encodings, therefore resulting TMPGEnc being 'dead' before when the batch encode ends. I'm running Windows XP, btw.
So... Anyone have the same experience with TooLame crashing occasionally? Or know of a 'fix'?
Unfortunately, it's something about the WAV file - it's very consistent when it happens.
There are 2 things you can do - use TMPGEnc without Toolame in this case, or there is a program called wav2mp
(http://www.mnsi.net/~jschlic1) that seems to do a reasonable job.
My guess is that anybody ripping the same DVD gets the same results.
If there's anybody who works on TooLame out there - I'd be happy to provide information on duplicating the crash.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10
