Is this conversion possible using Virtual Dub? I am thinking if you can get a codec and the correct settings then it could be possible. Any ideas on this?
Why not just use a mpeg2 encoder? TMpgenc, CCE Basic, Mainconcept or something. If you really want to user virtualdub(filters or cutting) then frameserve from virtualdub to the encoder
www.dvdrhelp.com/virtualdubframeserve -
I would really like something that is freeware. The MPEG 2 to tmpegenc only works for 30 days.
Standard quality/size for MPEG (*.mpg) videos?
By Ashman01 in forum Video ConversionReplies: 3Last Post: 22nd Feb 2009, 19:55 -
Card with mpeg-2 hardware capturing for standard definition?
By Giantsloth in forum Capturing and VCRReplies: 3Last Post: 27th Oct 2008, 19:26 -
BEST way to convert HD video to standard DVD?
By senorroboto2k5 in forum Authoring (DVD)Replies: 43Last Post: 14th Sep 2008, 03:35 -
Is there really such a thing as "standard mpeg 4 video"?
By yoda313 in forum Portable VideoReplies: 5Last Post: 25th May 2008, 13:16 -
Pioneer DV-400V Any way to play standard MPG/MPEG-2 files from USB or disc?
By flobie11 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 2nd Feb 2008, 07:09
