Hi all,
Wondering what everyone is using to take jpeg pics and create a slideshow with a mp3 sound track. I would like to be able to do this and burn to a DVD-R. Last time I used adobe premeir and manually added every pic and transition, was really slow and tedious process.
My pics are also 5megapixels so they are like 2560x1920, so I would also need a program that would either rescale these pics automatically or accept this resolution. Unless there's another program out there that could do a bulk resolution change...
Is there a decent program out there where I can just say add 200 jpegs, select random transitions, add a few mp3 music files and specify the seconds between displaying pics. That would be awesome, thanks in advance![]()
rhuala
p.s. Also, is there a program you would recommend for vcd or scvd format (for parent who don't own DVD burner)
I assume you mean for a DVD player not on DVD player. I use Dazzle DVD Complete for this, a lot of others will do the same but it's my wife's stuff and it is fast and easy. Limited motion menus and back ground with custom audio in slide show and menus. A nice presentation and fairly automated.
(;-{> Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Give ProShow a go and support this site's sponsor.
Very simple to use, does exactly as you want - drag and drop pics and mp3, with timings for slides and transitions, output to VCD/SVCD/XSVCD/DVD/MPEG/MPEG2/EXE
there's a link on the homepage (yellow ad) -
another option is ulead Movie Factory 2,
I use this programme quite often and is able to handle jpeg with mp3's. You can also create a menu if you have a load of pics then this could be an option.
you can get a 30 day free trial at
uk version http://www.ulead.co.uk/dmf/trial.htm
You can also use ulead Pictureslide show, a 15 day trial is availabe at
http://www.ulead.co.uk/dps/trial.htm
hope thats helps,
Puting a slide show and a video separately onto the same DVD
By coastie in forum Authoring (DVD)Replies: 3Last Post: 10th Sep 2011, 05:44 -
Need DVD Slide Show software recommendation FAST!
By lbblock in forum Newbie / General discussionsReplies: 11Last Post: 14th Mar 2010, 15:58 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 09:55 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37
