How do i get back my vcd product to avi to modify the result.
Please help...
jlk
Your VCD will have a dat file, use VCDGear to convert the dat file to an mpg file onto your hard drive. Then open the file in vdub, select video full processing mode choose compression codec if you want to use any, if you save it uncompressed the file will be extremely large. Then select file, save avi.
I had a successful conversion from AVI to VCD using VCDEasy. But I am not satisfied with the image. It's not really that bad but a little bit of snowy. Is it because of my computer capacity? or my digital video or my pinnacle software. Please i need help. I have an ongoing big project...
Thank you in advance.
Craig, you mentioned to convert vcd to avi was to use an vcdgear and i"m confused with what you mean vcdgear. pls reply...
No the dat file is basically an mpeg file but slightly modified for VCD. VCDgear just reverts the dat file back to mpeg with the MPG extension. If you want to encode the mpg file to avi you can then use vdub. Open the mpeg file in vdub select the compression codec you want to use and save the avi file. You can get vcdgear here.Originally Posted by rosero
https://www.videohelp.com/tools?toolsearch=vcdgear§ionselect=&orderby=Name
2.35:1 AVI plays back stretched on HDTV
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2011, 19:11 -
Burned DVD Back to .AVI
By Iambob in forum Video ConversionReplies: 9Last Post: 1st Jun 2010, 19:42 -
ripping a avi/mpeg back onto computer
By pw29010 in forum DVD RippingReplies: 2Last Post: 16th Feb 2009, 17:34 -
AVI back to Mini Dv
By thewdawg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 8th Oct 2008, 15:18 -
AVI file won't play back
By Clydesdale in forum Software PlayingReplies: 9Last Post: 4th Apr 2008, 00:22
