  1. alright i've tried using virtualdub 1.3 and 1.54 and i get teh same stupid error... after like 280mb... into the wave file that its saving it gives me an ACM reported error on audio decompress (200)......
    i tried using avi2wav... and the file saved its just that when i want to make a mpeg with tmpg.... the video lags like maybe 2 seconds.... .....
    and i dont know how to fix it.....
    oh yeah when i go into file information in virtual dub... for my audio stream the compression is fraunhofer IIS MPEG Layer-3 codec if that helps....
    and the video is done with divx pro 5.03 codec....
    i'm lost... can anyone help????
    i've downloaded like 20 movies... and they all work fine... just this one is being a pain...
  2. Member Sooner02's Avatar
    I was having this same problem. Try opening the AVI in Goldwave then saving the audio as a WAV. It seemed to work for me, but not sure if it altered the WAV file in any way...
