I get this picture when I try to burn with Nero. I used DVD decrypter and DVD2ONE and I'm not sure what this means. If anyone can explain if the movie will be playable on DVD players and also if it would be erasable (it is a DVD+RW) if it for some reason there is a problem with the burn. Thanks in advance
A multi-session disc is used mostly for data discs. That is, the session is not "closed." You can add more data later. If you are burning a movie, then you want to close the session after burning the movie. So, you do not want to create a "multi-session" disc. Also, there should be no problems erasing a DVD+RW as long as the burn was completely finished. You can ruin a disc by cancelling a burn session before the burn is complete. Let it finish, check it, then start over if you must.
Select Burn without multi session. This closes the disk out so your set top DVD player can play it, that is if you have one that will play DVDs burned by your player. Good luck. Multisession is for when you don;t want to close the disk out. Its most often used for CDR's when there is still space left on your disk. You could later go back and write to the disk again if you wanted to. I have never seen this before for a DVD burn before. When it doubt always burn using a DVD RW first to chaeck your setup. This way oif it don't work you don't end up with a coaster.
Yes, Ive tried to burn many times and end up with either a movie with no audio, movie+audio only for 5 min or so, or nothing at all. Just wanted to make sure that with the multi session that it is still erasable, so i can try again if need be. TY for you help and i will try it out and reply if there are problems
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 12:06 -
Nero Recode question
By wulf109 in forum Video ConversionReplies: 1Last Post: 4th Aug 2009, 08:55 -
nero 8 question
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 14:38 -
Nero 6 audio editing question
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2009, 00:53 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 15:23
