I need some help. I am trying to burn cd1 of Shrek Svcd which is only 790megs. My burner is an HP 8100i. I have tried to burn this with Fireburner using the bin/cue, through Cdrwin with the bin/cue and also with Nero 5.0.3.8 and none of them worked. The second cd was no problem burning but for some reason I don't know why the first cd won't. Should it be done as Disk At Once, or Track at once or Session at once? Could it be my burner or should I try a newer version of Nero 5.5.4 and see if that works. I've had this problem with a couple of other svcd's but most burn with no problems. Please, any advice would be helpfull.
