When I created a DVD through IFOedit, the play order of chapters got screwed up that the ending credits plays 1st and then the rest of the movie plays (in correct sequence). How do I use IFOedit make it play the 2nd chapter (start of the movie) and play the credits at the end?
Could someone point out for me a guide or website on how to read the IFO and bup files and how to edit them to change chapter play order.
Results 1 to 9 of 9
if it is vts_01_0
that what it sounds like
either delete it or rename it in order after the last vob -
I wish it was so easy!
unfortunately, each VOB file is not an individual chapter. There are 4 VOB files which consists of 9 chapters.
the credits are usually a small vob file
they usually seperate from the movie vob -
in my case, the last VOB includes a part of the last chapter of the movie and the credits.
if you could "re-rip" the dvd.... You could rip it so that each chapter had its own VOB with "smart ripper" then you could just rename your files... and use ifo edit
I guess the easiest solution is to re-rip the movie w/ dvddecrypter.
but I am still curious in how this can be edited in the IFO file. Unfortunately I haven't come across a good detailed guide on ifo file structures and how to edit them. I think I need to rearrange the cell order. just not 100% sure on how to do it in ifoedit. -
there is a setting
in smartripper that will make each chapter a vob file
then u could rename that vob or delete it
rip in movie mode
in the settings tab
on the movie part
in the file splitting section, check every chapter instead of the default max-filesize
Pioneer DV 585a playing several new movies in wrong chapter order.
By snirpens in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th Apr 2012, 14:52 -
Newbiest of the Newb> Basic rip/rearrange/reburn question
By Jen526 in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2012, 16:02 -
IFOEDIT edit chapter points?
By wulf109 in forum DVD RippingReplies: 4Last Post: 29th Oct 2011, 21:42 -
how to rearrange the movies in dvdlab
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2010, 07:18 -
Changing field order flags = losing chapter points.
By gadgetguy in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2008, 13:13
