    Apr 2003
    Uk England
    I have a VCD movie in PAL format that plays fine on pc and stand alone player.I want to make a multi dvd with this movie included.
    I have succesfully conveted a few movies using SVCD2DVDMPEG+ (great programm for noobs like me, nice work ChrissyBoy!)
    I convert the .cue files into mpg using isobuster, then i open SVCD2DVDMPEG+ and select mpg>ES , 352 > 1st Header , VCD format.
    And off it goes , i end up with 2 x Mpeg Media and 2 x Mpa Media, fine
    here is log details
    Starting (S)VCD2DVDMPG: v1.1.1192.19280
    Begin time: 01:40:13
    --- File details:
    C:\Documents and Settings\Mark\Desktop\Movie mpg's\pb1.mpg
    Mpeg 1 System File [Video/Audio]
    Muxrate : 1.39 Mbps
    Estimated Duration: 38:59.76s
    Aspect ratio 1/1 (VGA)
    Size [352 x 288] 25.00 fps 1.15 Mbps
    Audio : Mpeg 1 layer 2
    224 kbps 44100 Hz
    Stereo, No emphasis
    --- File details:
    C:\Documents and Settings\Mark\Desktop\Movie mpg's\pb2.mpg
    Muxrate : 1.39 Mbps
    Estimated Duration: 38:37.34s
    224 kbps 44100 Hz
    Stereo, No emphasis
    ******** Demultipexing original mpg files (step 1 of 4)
    ******** Resampling audio from 44.1 KHz to 48 KHz (step 2 of 4)
    ******** Multipexing elementry streams (step 3 of 4)
    ============ Complete ============
    looks fine to me , so i open up DVDLAB V1.1 and import the Mpa and Mpeg files that SVCD2DVDMPEG+ created.
    But when i move the video streams into the connection movie box all it shows is green frames!?!
    Also it reports errors of Aspect ratio not correct for dvd compliency!?!
    I have tried lots of different settings in SVCD2DVDMPEG+ but always the same result
    Been at this for 10 hours straight now, researched theese forums but still cant find the answer. I also tried just importing the original mpeg files off isobuster into dvdlab but same result.
    Plz Plz Plz any help will let me eventually sleep
    Thx and keep up the good work ChrissyBoy your programm was well worth the donation.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I'm afriad DVDLab doesn't like your sources. SVCD2DVDMPG isn't doing anything to the Aspect ratio - as you found yourself when importing the files straight into dvdlab. Try another authoring package for these mpegs. Another package might be more forgiving about the VGA (1:1) AR....
    Mmm that log is from the freeware version....
