I took a VCD and used VCD gear to bring the .dat file back into an MPEG. Been using TMPEGNC 2.5 to load the MPEG.. Which have always worked fine with me.. But my MPEG2 30 days expired kicked in so I had to switch from that to TMPGENC Plus 2.5.. But it will not load any of the mpegs that I've ran through VCD Gear. Anyone have any ideas on this?
That is only an mpeg2 decoder not an encoder. TMPGEnc does not come with an mpeg2 decoder, it is the encoder that expires after 30 days.
Nate, thanks for that link. It has gotten me a step further and here is what I got. First thing I did I loaded that editor (I believe it is) that came with that encoder. I didn't do anything I just opened the mpeg and just saved it. Opened TMPGENC and I was able to load the file then. The 2nd thing I tried was installed the that encoder in the TMPGENC directory and I also was able to load that file so now all is good as far as I can tell. I just hope that it is using the TMPG encoder instead of that one because it looked a little buggy. I just want to use whatever file I needed to load these mpegs whatever the hell is wrong with them I have no idea.
Mike
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
It's the classic 'Unsupported File' message.
