Am having big trouble with my conversions. When I load an XVID file into TMPGEnc and click start I get messages like 'invalid pointer operation', 'write error at address xxxx in kernel32.dll at yyyy' etc. Have been told to use the directshow multimedia plug in which does eliminate the errors mentioned (and also tells me that every file I load has 30fps!!!!) but the resulting mpeg plays fine for 8 seconds and then is jerky for around 2 seconds (like a webcam), fine again for 8 and then jerky for 2 again and so on.
An example of a file I'm converting (from GSpot):
Codec: XVID 576x240 23.976fps
Audio: 0x0055 (mp3) ID'd as MPEG-1 layer 3
What am I doing wrong? Do I need to install something or update something? It's really getting me down!![]()
Results 1 to 10 of 10
Up in the top right hand portion of G-spot does it say that Xvid Codec is not installed?
This is so much fun! -
GSpot tells me that the XVID codec IS installed. Bit more info to add:
Heard from one of the forums about a file called ffdshow. Installed this last night. What does this file do? Should I have had this installed previously to succesfully convert XVID files? Since, when I click on 'Codec IS installed (details)' it now tells me:
Directshow is apparently able to play the file as well, though it has selected a different codec, the ffdshow mpeg 4 video decoder, whose primary 4cc (XVID), is also identical to that of the file, making that selection equivalently as good. -
Have just tried loading an XVID file into TMPGEnc after installing ffdshow and with the directshow multimedia setting as high priority which beforehand made TMPGEnc supply 30fps for every AVI it's now telling me the correct frame rate. So, fingers crossed, the mpeg will convert properly..... Will post my findings tonight......
I had this problem and after hour of playing just gave up.
Used Virtualdub to re compress to another codec and then
TMPG accepted it -
I used to have probs with converting xvids but after installing ffdshow's xvid codec evrything was fine!
Encoding XVIDS using TmpGenc is usually much less painfull if you frameserve from virtualdub. Look in the guides for info on how to do this.
try to lower/high priority in TMPEG for directshow ... in enviroment settings
open xvid in TMPEG needs a especial settings, they are somewhere in this forum -
I would go with what bugster says, however try uninstalling tmpgenc first and then reinstalling.
Aare avi to vcd dvd svcd converter can do it, http://www.2shareit.com
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator bugster
App for converting .vob folders/files to DIVX or XVID?
By Newb787 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jul 2011, 14:21 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 12th Dec 2009, 23:44 -
WPL file converting help required
By cool4cats in forum Video Streaming DownloadingReplies: 1Last Post: 25th Nov 2008, 06:41 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 14:34 -
Converting XVID files so XBMC will play them?
By skorch in forum Video ConversionReplies: 3Last Post: 19th Jun 2007, 11:32
