where can d/l mpeg2 plugin for tmpegnc instead of the tmpgenc plugin on the tool page
What do you want. Do you want an mpeg2 decoder that allows TMPGEnc to open mpeg2 files. Or do tou want TMPGEnc mpeg2 encoder that expires after 30 days.
If it is the first option install powerDVD the trial version will do. This will install an mpeg2 decoder that TMPGEnc can use to open mpeg2 files. You can uninstall it after if you wish and the decoder will remain.
If it is the second option then buy the full version of TMPGEnc.
Virtualdub Colortools Plugin
By poisondeathray in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2013, 12:02 -
Is there a software or plugin?
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2011, 21:43 -
The Best Video Plugin Ever!!
By DemonSeed in forum Media Center PC / MediaCentersReplies: 20Last Post: 18th May 2009, 13:59 -
vegas plugin
By wingfan in forum EditingReplies: 5Last Post: 10th Nov 2008, 10:33 -
quicktime plugin
By geonuine in forum Video Streaming DownloadingReplies: 7Last Post: 17th Jul 2008, 20:38
