I have an AVI that is 720 x 416, if I watch it like that the frames are shrunk horizontally. The correct dimensions are 720 x 320.
I am using DVD2SVCD to convert it and it looks like in Frameserver tab there are resize and borders capabilities. I assume I have to edit the AVISynth script at one point. Considering that I am using TMPGEnc and am trying to create a standard SVCD how should I do this ?
Simon
Dont know about DVD2SVCD as I don't use it, but this is easy to do with vdub. Open the file and simply select the resize filter input your new size and frameserve it to TMPGEnc.
there is a tab option in dvd2svcd that if you choose it then you can edit the avisynth script on the fly.
Resize video without converting
By JOHNINA in forum Video ConversionReplies: 6Last Post: 27th Feb 2010, 22:25 -
Want to resize an avi
By janlafata in forum Video ConversionReplies: 2Last Post: 18th Aug 2009, 00:06 -
.avi to DVD + resize
By grandsire02 in forum Video ConversionReplies: 2Last Post: 9th Mar 2009, 18:28 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41
