I tried to convert a DIVx to VCD. But the sound get
out of sync.
I first tried to convert with TMPGEnc 1.2j without luck.
After that, i tried to rip the sound from the file,
with VirtualDub 1.4.7 (couldn't find Virtualdub 1.3c),
and used that with TMPGEnc. Still the sound is out
of sync.
Any suggestions?
Guest
Make sure the source material is in sync. Check this first. You can try extracting the audio from the DivX and save it as an uncompressed wav file. So instead of audio -> direct stream copy select audio -> full processing mode in VirtualDub. Then select compression -> None (PCM wav). Use the save wav option under file.
Regards,
Willem
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 11:19 -
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 12:48 -
Divx sound sync issues
By hotsalt in forum Video ConversionReplies: 1Last Post: 11th Apr 2008, 15:18 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 10:31 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 21:11
