  1. After reading many posts and doing many experiments, I finally converted a .mpg to .bin and burned in Nero. This resulting in an SVCD's that now FF/RW.
    BUT
    I did this procedure the other day....no prob, worked like a charm. Today, I went to burn two more movies on two different computers with the same versions of Nero (5.5.2.4) and VCDImager (.6), same media as the other day, and all I get is a blue screen. The DVD (Apex 703) appears to be reading the disc, but when I hit play (or I've tried overriding PBC), the screen and counter just sit there, blue. Yes, I'm loading the .cue and insuring it's path line is correct, and I tried Nero 5.5.1.1, all with the same result. The original .mpg's play normally on both computers. I've gone over the conversion/burning directions a zillion times, and I'm following it to the letter. The ONLY thing different is the burner. The burner's I used today are Mitsumi, and yesterdays was another brand (came with my Dell). Could it be the burner (I can't test right now as I have a movie processing on it until tomorrow night)? Is there and installation procedure for VCDImager other than unzip and run the .exe? Am I missing something really stupid?
    Any help is greatly appreciated.
    Mike
  2. ...there have been some reports about nero misburning bin/cue images...
    please see
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=49024&forum=1
    maybe things discussed there apply to your case!
  3. Well.....
    I can now verify that my Mitsumi burners will not properly burn a .bin file. The other burner I have which came bundled with my Dell (I have no idea what it is) will consistently burn .bin's, no problem. Go figure......
    Good luck
    Mike
  4. My Mitsumi will burn BIN/CUE images with CDRWin, but not with Nero.
  5. Try using cdrdao to burn the bin/cue.
  6. Thanks gang!
    Mike
