Hiya
I have 3 bin/cue files for a couple of SVCDs. The first 2 are great and burn just fine with Nero, but the 3rd disc is too big. Is there a way to make it smaller or 'burn' to a file (mpeg) that I can then crop to 800 mb using some other software? The bin/cues were made using DVD2SVCD.
The 3rd disc is typically 850-875 MB (if I could burn it anyway). Nero just says no-way...
Thanks for any helpful advice!
Homes
you could use deamon to mount the bin file, use tmpgenc to cut the mpeg into 2 files, then use vcdeasy to make 2 new cue/bins
Why is the Bin/Cue too big? Did you make it? Did it need autopadding?
Sometimes if you make (S)VCD's that aren't muxed correctly, the resulting bin/cue could be HUGE.
If you made it and it needed autopadding, you may want to remux the mpeg as Vide CD instead of mpeg, and re-make the bin/cue.
If not....well....I don't know. I guess what Ejoc said.
Good Luck!
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
