I don't see this all of the time but it does happen on occassion and don't know what's causing it or what can fix it. Here's the problem...
I'll import my file and demux, then I set the chapter points, I double check each chapter point before and after creating the menu and links, all right on the mark. But then, once I play my burned DVD back on my topset, some of the chapter points are off by a few seconds (generally 2-3 secs). This doesn't happen all of the time but it does happen. Anyone know why this happens and how to fix it?
The video file I'm using is in MPEGII format DVD-Compliant, capture with a Dazzle DVC150, avg/max bitrate set to 4200/6000.
Any help would be appreciated,
ChachiFace
