for some strange reason, DVD Backup1.3 cannot decode Video_TS.VOB of The Animatrix DVD. It did all the other files alright, but not that one. So I took the DVD to my friend's house and tried DVD Decrypter on his PC. It worked fine. The strange part of it is that all the keys are the same. So I burned Video_TS.VOB to a CD and took it back to my iMac and everything work perfect. Anyone else with this issue?
Can't say that I have, on any of the dvd's ive done, and I dont own animatrix yet.Originally Posted by yubie
but it looks like you were able to go around the issue, which is good. The VIDEO_TS.VOB file isnt very large, and i would imagine you could just pull it directly off the mounted dvd like you are copying it from the disk to your HD.
or you could try another backup program other than dvdbackup. but the important thing is you got it! -
I think it has some form of protection or something but I managed to copy it
DVDbackup wouldnt allow me to make an image I could use in DTOX but DVD extractor did.
https://www.videohelp.com/forum/viewtopic.php?t=161653&highlight= -
I've had similar problems with DVDBackUp 1.3, most recently with Star Trek Nemesis. I also had the errors mentioned in the other linked thread with OSEx. Finally, I used the Finder to copy and paste the DVD to the HD, then DVDBackup worked on the files from the HD fine. The 'Diskcopy' results from DTOX worked fine with Apple's DVD Player. Did you try that? Just wondering.
tugboat, yes, i did try copying the file to the HD and use DVDBackup on it. It did not work.
I just backed up The Animatrix DVD with DVDBackUp 1.3. Then used DVD2oneX 1.1.0 and everything worked just fine. No problems.
G4
466mhz
OSX 10.2.6
Just a heads up, I also backed up Animatrix Region 1 DVD without any trouble using Backup 1.3.
Excellent
I have also since this posting. Great movie!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
