I am having a problem with pinnacle studio deluxe, when I capture analogue video and audio the audio sync becomes unstable after approx 20mins of captured video, the audio is about half second out of sync. Any ideas folks?
The problem is not there when only a short video clip is captured.
What is your source?
If it's analogue and your source is anything other than perfect then you're wasting your time.
I have Pinnacle Studio 8.5 and wouldn't dream of using it for capturing anaolgue, it's shite.
I use virtualdub and open with Studio to edit, add transitions etc then encode with TMPGEnc and author with Ulead Movie Factory.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Yep, that's true about PS8. I use scLive version 2.0 to capture, everything else in PS8. No A/V Sync problems with scLive. This problem is supposed to be addressed in the Beta Version 8.7 of Studio.
http://scenalyzer.com/main.htmlGeronimo -
Hi,
Did you solve your problem?
I'm trying to put together a post on audio/video sync problems and would appreciate your input.
Thanks,
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio/video out of sync
By gibsonpm in forum Video ConversionReplies: 4Last Post: 30th Jan 2010, 05:53 -
Video Audio sync help
By carasy in forum Newbie / General discussionsReplies: 10Last Post: 19th Nov 2009, 19:09
