I found some mpeg files and downloaded those to view. But, I have a problem with them and for the life of me, I cant figure out what is causing this. what it will do is when i load it up it will load the first frame, but will not play it, it just immediately goes to stop, then if i move to say the middle, and press play it will just go back to the first frame and stop agian.
I have been able to open it up in V-Dub, and its all there, but i dont want it in avi format unless i have to do it that way, it wont direct stream to a .mpg.
I hope this didnt just make it sound more complicated than it is hehe.............
i got it to work by using TMPgEnc, and it played. the volume is way out of sync, but it didnt really matter that much because it was only WWF wrestling, and not a movie.
Sorry if this took too much of your time, by the the info will probably come in handy another time for me, if you have any info about it. 'Cause i convert all DivX to VCD any how.
sounds to me like these files have a nasty bumper at the beginning...get vcdgear 2.0 with gui and run a mpeg -> mpeg conversionm, while choose "fix mpeg errors" and "remove CD-i MPEG bumper"
first time problem : can't find boot dsk on startup
By beavereater in forum ComputerReplies: 22Last Post: 24th Jun 2011, 17:09 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 21:34 -
Problem: converters can't find Real Alternative
By Leftee in forum Video ConversionReplies: 0Last Post: 11th Feb 2010, 14:24 -
has anyone find out what the problem is?
By suav3sito in forum SubtitleReplies: 0Last Post: 12th Aug 2008, 15:28 -
Problem with Ffmpegx v 009y: can't find progress.app
By cellocgw in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2008, 18:16
