What is the best program to use for burning movies to DVD plz.
thanks lemtech
#1 do not ask "what is best", there is NO answer to this question in any aspect. there is no best player, encoder, format, or anything else for that matter. the best is what works best for you and only YOU can tell what works best for you.
that's not "freeware", that's just a bad protection scheme.Also it is a freeware. 30 day full version trial. After 30 days either by it or download the newest version for another 30 days, and so on.
free trial or not, if they expect you to pay, it's shareware at the very least.
as for what I use to burn - Nero. Right now I'm using version 5.5.10.20, works fine.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Many people in this forum find great success with RecordNow Max. I have both Nero and RCM, but use RCM because of version issues with Nero while burning DVDs. I think those issues with Nero have been ironed out with later versions though.
DVD Authoring Programs Disappear In The Midst of Burning Stage.
By mungbean34 in forum Authoring (DVD)Replies: 9Last Post: 13th Jul 2010, 02:21 -
What do you use?? Essentials ie codecs and programs for ripping and burning
By R!ffraff in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2009, 04:36 -
Burning programs to burn multisesscion of photos on DVD-R
By better life in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2008, 07:29 -
The best Converting/Burning/Authoring programs?
By whatever911 in forum Authoring (DVD)Replies: 11Last Post: 23rd Jul 2007, 14:01 -
which of the free burning programs is the best?
By nobbyiscool in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2007, 03:49
