Hi,
I DLed the demo of Stream Anywhere and while it successfully encodes short MPEGs of 3-5 minutes or less as RMs, it fails with anything longer. Can anyone suggest another app that can encode longer files? Also, I was hoping to convert DIVX to VCD - can anyone tell me how to get around the file size problem? How can I cut a DIVX AVI file in half, since I assume once it's converted to MPEG it will be huge...
Thanks for any advice anyone can give me!
-ThePete
REAL PRODUCER PLUS encodes RealMedia (I'm not sure how long the files can be but try it)
It's available here: (just sign up to yahoo group - 1 min process) and go to the FILES section:
Get HJSPLIT also available at the group above, download the 4 parts (.001-004) of realproducer plus and join them with hjsplit and unzip. enjoy. Oh yeah get this file also realpro*******.txt ... you'll need it. -
OOPS, the site is here:
http://groups.yahoo.com/group/buzzinhornetz2001/files/ -
Hey! Thanks - that seems to be doing the trick just fine! Much obliged, feller! Nice little list you've got going there, too. Quite a little treasure trove of goodies! Thanks so much!
-ThePete -
Correction - this app ROCKS - thanks so much, Buzz!! It supports everything - AWESOME!! THANKS AGAIN! -ThePete
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
"Where's progress app?" error when trying to decode VCD
By rossi in forum ffmpegX general discussionReplies: 8Last Post: 19th Aug 2008, 00:48 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
