Hi,
I want to take my DV tapes and create a DVD with menus etc and perhaps some photo slideshows on the disc as well.
I have Premiere and CCE-SP. If needs be, I could buy some other software.
I'm confused on the best route to create the final DVD MPEG.
Once the DV is loaded into premiere, and I have done my editing, should I either:
1. use the adobe CCE plugin to create my DVD file.
2. use the standalone CCE and convert my avi this way
3. someother way?
Oh, and while we're here - if my audio is at 32 (not 48) - which is the best way to upsample - using adobe/cce or some otherway?
Thanks!
I'm trying to get the ULTIMATE homemovie DV to DVD transfer that I can 8)
I'm not familiar with the Premiere CCE plugin, but I have Premiere 6.5 that comes with MainConcept, and I also have the MainConcept standalone, so it's a similar situation.
Nearly always use the MainConcept from within Premiere -- it's lightning fast and outputs the same as the standalone. With 6.5 you can even do batch processing, in case I need to do multiple projects while I sleep.
I output to multiple streams, and this takes care of any audio processing so I don't worry about upsampling or whatever.
Finally, I import the elemental streams into DVDLab -- terrific authoring tool, but doesn't directly support slideshows (that is, you either need to create them in Premiere, which is easy and good if you want transitions, or you need to use another tool like Picture Show to create them as non-transition stills and import the asset into DVDLab).
Works for me."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
DVD -> Mpeg Streamclip -> Virtual Dub -> Premiere CS4 workflow. Help!
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 15th Jun 2011, 01:26 -
VHS to DVD workflow
By robjv1 in forum RestorationReplies: 3Last Post: 26th Feb 2010, 11:59 -
AVCHD native workflow in Premiere CS3 and CS4
By rallymax in forum EditingReplies: 8Last Post: 8th Aug 2009, 20:21 -
AVCHD to DVD workflow advice
By petem23 in forum Video ConversionReplies: 3Last Post: 16th May 2009, 08:57 -
Workflow for AVCHD > Premiere > DVD/Web
By phowe in forum Newbie / General discussionsReplies: 5Last Post: 13th Jan 2009, 11:03
