  1. Anonymous
    Guest
    Hi all, probably I am going to ask a stupid question but I am really not an expert in this subject. I have got a video that ffmpegX recognizes as
    XVID 480x352 16bpp 25.00 882.8 kbps
    and I want to convert it to a vcd or a svcd (to see it on my home dvd).
    The problem is that when I select VCD (PAL) quick Presets and changed the tab Autosize to unconstarined and set the Video size to 480x352 the video becomes streched and 2 black bars are added....
    Is there a way to create a vcd readeable on a PAL home dvd without deforming the image?
    suggestion?
    Thanx
    reb
  2. A VCD has very specific image size. If you change it, it will not play it on compliant players. Check "What is VCD / SVCD" on this site left navigation bar.
