I have an AVI that has it's Audio and Video out of sync. I have corrected this by changing the framerate from 25.000 to 25.056. Now the AVI is in perfect sync, but when I convert it to mpg format with TMPGEnc (for PAL) I end up with the same result as I started with, Audio out of sync! This is obviously because the framerate is converted back to 25.000 with TMPGEnc. Now can I somehow convert with TMPGE at a framerate of 25.056? With the version I have I don't seem to be able to. Can another version do it? If not what else can I do? I plan to play it on a DVD player.
Please help. Thanks.
Results 1 to 1 of 1
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Does not work.. What can i do?
By schr2004 in forum ffmpegX general discussionReplies: 0Last Post: 24th Jul 2010, 16:21 -
Can't get it to work???
By rjocon in forum ffmpegX general discussionReplies: 1Last Post: 12th May 2009, 17:00 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35
