Hey guys i am new to this forum.I have a serious problem ,The other day i was backing up one of my movies using dvd x copy.After it was finished it completely froze up on me,I could not close any programs for a couple of hours i had no other choice but to restart the computer ,Thats when this happened When i went back in to dvd x copy i noticed that i did not have enough space to copy any more movies.I only have 2 gigs left on my c drive .My question is does any one know what i can do to fix this problem. I have already uninstalled the program but no luck...PLEASE any help would be great
Make more space and copy again. In xcopy you change the temp folder by going in option. - B
That the problem i cant make any more space i have lost all of the memory on my entire c drive .I have already removed enough programs i need the rest of them.Every time i chang the temp drive to the d drive it just freezes up .
Be sure to empty the Recycle bin.
"Art is making something out of nothing and selling it." - Frank Zappa -
DVDXCOPY uses the users temp folder this is usually hidden you have to go to explorer and click to view hidden files. Then go to C:\Documents and Settings look for your logon name and look for the temp folder. You can delete anything that's there. If DVDXcopy crashes it wont cleanup.
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Subs When They Are Needed
By urb1972 in forum SubtitleReplies: 1Last Post: 28th Feb 2008, 15:03 -
Hack needed
By chisholmh1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Dec 2007, 10:32 -
Compressor Needed
By mytabbycat in forum MacReplies: 4Last Post: 3rd Nov 2007, 05:54 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
