  1. I'm trying to back up a DVD and there is two different chapters of the same thing. I only need one, but when I try and deselect one of them, they both deselect. I'm using the registry hack for Instant Copy. I used DVD Decrypter and ripped the disc in whole to my drive. I'm sure the answer probably lies with a VOB editor or something like that, but I'm new at this and was wondering if anyone else has run across this. Thanks.
  2. I'd would use IFOEdit, DVD toolbox or DVD Shrink to strip out the titlesets you do not want, generate a new VIDEO_TS folder, and feed that to IC. The IC reghack is not very good.
  3. Would it also be possible just not to rip the files that I'm having problems with when I transfer the files using DVD-Decrypter? Or would that possibly cause more of a headache? I'll check into the other software that you suggested and see if I can figure out what I'm doing. Thanks for the reply.
