I need to remove a frozen frame so I can rip to VCD using TMPGEnc. I load the file in VirtualDub, but nothing comes up on the screen. Then when I attempt to play I get the error message:
VideoSourceAVI: uncompressed frame is short (expected 253440 bytes, got 9061)
I figure that I must have the codecs installed because the file will play without any problem. Please help. I have lots of files that I need to cut out frames for so this is a big problem for me.
k@mhz.com.au
Results 1 to 1 of 1
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 17:49 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
VirtualDub "NewMovieFromFile" error w/mp4 file
By smk42 in forum EditingReplies: 3Last Post: 31st Dec 2009, 00:37 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 15:19 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 18:09
