my source is 512 x 288 DIVX @ 25fps 16:9
i'd like to convert to VCD and burn but my question is what settings should i use in tmpgenc? i'm not sure what to put in the source aspect ratio pulldown box because although the resolution seems to be NTSC, the framerate is PAL. and should i choose NTSC 4:3 in the video stream settings to fit on a standard TV? i imagine it's not good to convert from PAL to NTSC and vice-versa.
plus, is fitting it on one CD advisable? i used the bitrate calc and got 1039kbps as the bitrate to fit on one 80-min disc. the length of the movie is 1hr 27m and it's a dvd-rip, so quality is good.
"as copied from front page"
PAL
Video:
1150 kbit/sec MPEG-1
352 x 288 pixels
25 frames/second
I think converting to PAL would be easiest, since the framerate is already 25fps. -
don't worry about the resolution. that is an easy, relatively high quality conversion. just worry about the framerate. If you converted to ntsc instead of pal your video would be jerky because the framerates arent integer factors of each other and tmpg doesn't know to do a real pal-->ntsc conversion.
What progam does know how to do a 'real' PAL to NTSC framerate conversion? I have a PAL movie I want to convert to NTSC and burn to a DVD.
cheers. -
http://www.dvunlimited.com/
Go here to find a true PAL/NTSC DV video software converter. -
There are plenty of threads and several guides on various framerate conversion techniques on these forums. Try using the search box at the top of this page and you will find loads of info to help you.
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
how to convert ntsc to pal without changin the resolution?
By Remyisme in forum Newbie / General discussionsReplies: 6Last Post: 27th Mar 2009, 18:30 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
PAL is bigger resolution than NTSC....?
By snadge in forum Newbie / General discussionsReplies: 17Last Post: 19th Jan 2008, 13:18
