  1. I can't seem to get Scenarist to load up an SVCD. (My work owns a copy of Scenarist, lucky me.) Anyway I tried patching the first header and the whole file, but no luck. Any suggestions I can try when I go back to work tomorow?
  2. Hmm appears to be that it checks the GOP. Is the only difference between SVCD GOP's and DVD GOP's that SVCD=0 and DVD=1? If so is there a fast way to change the 0-->1
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I think you'll find that some of the "high end" authoring applications - Scenarist being one - check on GOP# as well as resolution..... Nothing to be done I'm afraid. ReelDVD is another one.
