I can create a movie by using smart ripper then using tmpg and then bringing into dvd complete and making it there. When using DVD2one, it works on some players and not on the panasonic DVD in my suburban. Basically I know it is not the media and not the burner. Is there something on a DVD file that would tell the player to expect a larger DVD than what it sees?
Any Ideas?
Only thing I can think of is that maybe your panasonic dvd player in the suburban doesn't play dvd+r or what ever form of dvd media you are using.
Thanks for the replies but as I said, I don't think it is the media as I can already use the media fine if I author a different way. I can author a DVD using DVD complete with the same media and it works fine. I don't think it is the DVDR media.
Can anyone help me get the serial number for the dvd2one v.1.20 , Ive tryed looking everywhere...
please email it to me nish49ers@msn.com
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator tgpo
is that a request..?
no SERIAL, CRACKS or whatsoever or you'll be crucified..
I FEAR NO BEER!!! -
Problem resolved.
Reading some posts from other messages, users suggested I use COPYTODVD to do the burning. I used the program that came with my DVD burner previously.
DVD2ONE has a nice feature, if you use COPYTODVD , you can select to burn disk at end of reencoding. I used the trial version of COPYTODVD and now It will work. Gonna buy that now.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
