It's just 4mb to large and Nero or Alcohol 120% wont burn it. Can I do anything about this? It's already is bin/cue format and it's a SVCD.
Results 1 to 17 of 17
In fact, the capacity of an 80 min. CD in (S)VCD format is 800 MB. so you should have plenty of room to spare. I think you've got some other problem.
"Art is making something out of nothing and selling it." - Frank Zappa -
Try extracting the mpeg from the bin using vcdgear and reauthoring.
Oops, yeah you're right. I was looking at the little bar on the bottum; but yeah, the actual mpeg2 file is over 800MB.Originally Posted by ZippyP.
By how much? If you can enable overburn (does nero do that?) you should be able to get a few extra MB's.Originally Posted by Taylor"Art is making something out of nothing and selling it." - Frank Zappa
Nero is capable of overburning with compatible drives.
It's 837MB... I'm not sure if Nero has overburn, but 37mb is probably to much anyway.
Reauthor? How? TMPGEnc won't let me open the mpeg I extracted using vcdgear.Originally Posted by Craig Tucker
No you would not overburn it that much. I would suggest extracting the mpeg from the bin then splitting it in half and burning it on 2 discs.
I would if TMPGEnc would let me. What other programs can do it?Originally Posted by Craig Tucker
Could be that you do not have an mpeg2 codec installed, so TMPGEnc can not open your mpeg2 file. Try installing the trial version of powerDVD(this will install an mpeg2 codec) and then see if it will open.
It seems to have worked.... Nero said it was only 804MB while burning...
Thanks -
I have PowerDVD, the full version... TMPGEnc just wasn't happy for some reason.Originally Posted by Craig Tucker
In Nero click on file, preferences, expert features and tick enable overburn. Check that your CDRW drive supports overburning first.Originally Posted by Fisel
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
