I am having a problem with cue files that I get from the newsgroups.
They don't seem to burn correct I get a buffer underun error, if I rip it in vcdeasy then re- encode it in vcdeasy it's fine.
The files aren't in PAL format I checked that already.
Any Ideas?
Many Thanks
So many buttons
Did you edit the cue file so it has the right path to the bin in it? just use any text editor to see.
Cue File With Media Player Classic 64
By mugly78643 in forum AudioReplies: 1Last Post: 2nd Jun 2009, 03:42 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 12:29
