This is out of curiousity i was just thinking about it as I was sitting here at work...
i own a dvd.. - rip it using DVD DEcrypter - now its on my hard drive
use DVD2one or whatever compression tool i want and use nero to burn to cd..
now.. does that mean that the "new" dvd can be copied as a "copy disc" or it would have to be Decrypted again?
again this would serve no pratical use .. i was just thinking... and wondering
The new disc has had the encryption removed, so it can be easily copied using Nero, RecordNow or whatever. It does have practical value -- I do it often. Also, there is a lot of nonsense floating around this forum that DVDXCopy discs can't be copied -- Not true!....does that mean that the "new" dvd can be copied as a "copy disc" or it would have to be Decrypted again?
LTA
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 16:04 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 20:10 -
ATSC Tuner Question with DVD Player/Recorder/VHS Combo Unit
By Surfmaster in forum DVB / IPTVReplies: 4Last Post: 17th Dec 2007, 20:01
