Hi,
I currently live in the UK and have a NTL Digital box that I would like to capture images from at the best possible quality.
However, the box only has RGB and Composite outputs.
How much better would Svideo be in comparison to a Composite signal in terms of capture?
Im looking at this converter, http://www.rgbtosvideo.com/rgb-sv/rgb-circuit.htm to convert the RGB signal to Svideo to my VIVO card. Can anyone confirm that this would/not work?
Any help would be greatly appreciated,
Regards
At £75 its a fair amount to pay, and I am wondering whether or not the increase in picture quality (if there is any) would justify it. Would a step up from Composite to Svideo be significant?
depends on your standard of quality ... for dvd i would say yes -- for vcd or svcd i would say its up to you but prob. not worth it
scrolling picture problem with svideo
By slyder0244 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jun 2009, 19:35 -
HDMI to Svideo or Composite?
By cdgtcc in forum DVB / IPTVReplies: 1Last Post: 14th Nov 2008, 05:53 -
SVIDEO Question
By jhorak101 in forum Newbie / General discussionsReplies: 3Last Post: 19th Jan 2008, 00:47 -
pc to tv svideo?
By xbill in forum Newbie / General discussionsReplies: 19Last Post: 15th Jan 2008, 11:31 -
Connecting my PC to TV via svideo.
By chronic777 in forum Software PlayingReplies: 2Last Post: 12th Sep 2007, 01:06
