    Portugal
    Hi,
    i'm trying to convert this avi:
    to s-vcd format with TMPGEnc and when converting it appears like the image is meltting down, with pixels out of the place.
    I want to know if it already happened with any of you, and how can i solve it?
    tnx,
    -Mithrill-
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    try using a newer version xvid codec
    Portugal
    Yes, i'm converting yet but, that seems to solve my problem.
    Your reply was of great help. I never thought it was from a codec problem because i use to convert avi with xvid a lot, and never had this issue.
    many tnx,
    -Mithrill-
