Is there a way to convert NTSC film to PAL format? I've tried to play NTCS Film based VCDs in my DVD player but it doesn't work well so i'd like to change it to PAL format. My DVD player is VCD compatible.
re-encode to PAL format? i don't really know... maybe some experts in here can give you some shortcuts so u don't have to re-encode.
you could try useing TMPGEnc it covet nstc to pal for more info look under the convert link to the left of here it should tell you more about it.
gerily -
I don't advise you to do so, because you've got a chance the audio will get desynchronised.
The only save sollution would be at capture-time. When I want to create NTSC but my video-source is PAL, I force the capture to take 29.97 fps instead of the default of 25.
VDub will then insert a lot of duplicates to fill the 'gaps' between the 25 and 29.97 frames, so the audio can keep up, but the result is good. TMPGenc will accept the avi as NTSC.
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 10:40 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 11:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26
