  1. Using ACS200 Hardware I convert Hi8 video to MPEG2 files. This I then convert and burn as DVD compatible files using Nero software. The DVD simulator displays the DVD perfectly, but when I place it in my LG DC-595NWQ it does not play - I get the message "No MP3 File".
    1) What does this mean ?
    2) What can I do to fix it ?
  2. I can see by your post # you are new.
    So, first check your LG DC-595NWQ compatibility with the type media you are using... + -
    <--------- look over here for DVD player compatibility and search for you model.
    Don't give in to DVD2ONE, that leads to the dark side.
